The #s look ok, the booster isn't leaking if the vacuum stays the same
after the engine is off.
Check the throttle kicker and throttle cable for binding, I've replaced my
throttle cable 2 times now because it worn out and broke, you might be
getting some binding because of that, it starts to fray the cable where
it goes through the fire wall, above the pedal, look there for cable damage
