I have Maxxis 30x9.5x15 tires on Cragar soft 8 8" rims. I am using 1 .25' wheel spacers. My suspension is RUFF (rear springs up front). I have 2" Calamini rear springs. For the steering I do have a 3" drop pitman arm. My front and rear driveshafts have 1" spacers. brakelines were extended 3" with braided lines. Shocks are extended 3" over stock Calamini.
This sounds like alot but it really isn't. Depending on the type of driving you do you could probally grt by with less if it is mostly on the road. (shocks, brakelines, pitman arm)
Irregardless this is my set up for the tires you indicated.
