rims for 30x9.5 tire?
  • 7 Replies
  • 2338 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: April 21, 2016, 11:07:04 AM »
How wide, what offset/ backspacing should I go with?
Offline WVzuk
  • 181
Re: rims for 30x9.5 tire?
« Reply #1 on: April 21, 2016, 12:16:52 PM »
15x7  3.75BS
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #2 on: April 22, 2016, 04:23:14 PM »
Or... you could just mount them on your OEM stock 5.5" steel or 6" alloy rims.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #3 on: April 22, 2016, 06:56:42 PM »
I thought about mounting it on the stock alloys, but 9.5 wide seems too wide, isn't it?
« Reply #4 on: April 22, 2016, 10:06:22 PM »
That is what we ran on our race car with no problems.  And you can air them way down.
Offline WVzuk
  • 181
« Reply #5 on: April 25, 2016, 05:57:55 AM »
I had my 30 x 9.50s on stock rims and they were fine but when I switched to 15x7, the on road handling and stability was much better.  Don't for 15x8 or you will loose the bead when airing down lower than 15-18psi.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #6 on: April 25, 2016, 09:03:51 AM »
I picked up a ford f150 7.5 wide aluminum rims.  They're quite heavy duty, if I had a lathe I'd skim a bit off to save some weight.  Now to go get the tires
Offline beagle..t
  • 1239
  • 16
« Reply #7 on: April 25, 2016, 06:05:22 PM »
just make sure center hole is 108mm or they wont fit over front hubs
