rear end bump stop bottom out.
  • 0 Replies
  • 814 Views
« on: October 07, 2011, 06:02:44 PM »
i got a 87 samurai with a spring over lift, with stock springs. when i hit a good bump the bump stops hit rear spring plates. whats the best way to fix it? also i was thinking about order the calmini 3" under the axle lift kit, will this fix it? i need to clear  29" super swampers for tires.
