Duty Check Coupler?
  • 1466 Views
Offline kelly mt
  • 22
  • The Samurai on The Mountain
Duty Check Coupler?
« on: October 06, 2011, 08:28:27 PM »
What is the Duty Check Coupler used for?
Offline mrfuelish
  • 2862
Re: Duty Check Coupler?
« Reply #1 on: October 06, 2011, 09:05:27 PM »
to set your idle air adjustment.
Offline kelly mt
  • 22
« Reply #2 on: October 06, 2011, 09:26:01 PM »
What do you plug in? I haven't got that far in the maintenance book. Ran across it while looking for a switched source for my tach. PK
  • 4313
  • 167
« Reply #3 on: October 07, 2011, 04:50:04 AM »
It may depend on the vehicle and the year of manufacture - I can use mine to "freeze" the ignition advance, allowing me to set the base ignition timing, and also to get any active CEL codes.
Offline rascott
  • 669
  • 15
« Reply #4 on: October 07, 2011, 10:09:50 AM »
i have used the connector to adjust the idle mixture(after removing the anti-tamper pin).
i used a dwell meter..... not a quality unit, but it did act as the manual predicted.
i have the carbureted sidekick, but i expect it's similar to the samurai.
