Hello. Having problems getting the Zuk to pass smog because it won't idle under 1200 rpm. Here is what I've done so far - cause it was cheap and easy:
New fuel filter, new plug wires, new plugs, new distributor cap, new ignition rotor, new vacuum lines, new carburetor bottom gaskets at the intake manifold, adjusted valve lash -- still same symptoms. It runs great under power and will idle all day at 1500rpm. As soon as I try to dial back the rpm using the the idle screw, it will die. Also of note is that when I pulled the old spark plugs out, they had a little bit of clumpy white crud on the tips (burning oil from piston rings or valves).
Today after replacing the bottom carb gasket trying to eliminate any trace vacuum leaks, I decided to mess with the air mixture screw and I noticed something odd.
The screw has absolutely no effect. All the way in, all the way out -- the engine runs exactly the same. Is there some gasket around the needle that I need to replace? Registration is due at the end of the month and I can't get the dang thing to idle low enough to pass smog AAAArgh.
Thanks for any insight.
Mat (Las Vegas, NV)
