Hello everyone, new to Zukiworld, long time Tracker owner. Recently I bought a 97 Tracker 4dr LSI 2wd. First problem, the car wont start in Park, I can hear the starter click but nothin, if I put it in neutral, it will fire right up. The last owner just replaced the ignition switch, starter and battery trying to fix the problem (All parts replaced 2 months ago). Second, once it starts, and warms up, it wont hold an idle. It drives fine, but once you come to a stop, the engine will die. It will stay running if you rest your foot on the throttle, no missing or rough running. I've had it for a week, and I've only changed the oil, fuel filter and pads/rotors. Anything I should check out? Thanks!!
