What toy suspension is good for a dd?
  • 9 Replies
  • 1687 Views
« on: June 22, 2011, 11:46:20 AM »
I'm thinking about doing a 1.9td swap and I heard the extra poer can snap the zuk axels and such. So instead of buying an adapter for a zuk trans and switching to a toyota I rather do it all at once. Should I use the later toyota models like 86-93 axels or the pre 85? Or can I use 4runner axels? Remember I'm not a rock crawler I will only do easy trails and use it as a DD
Re: What toy suspension is good for a dd?
« Reply #1 on: June 22, 2011, 04:29:58 PM »
Is this for a Sammy or Tracker?  And are you looking for the best or most affordable?  :)
« Reply #2 on: June 23, 2011, 01:21:01 AM »
Sammi sorry. I'm looking for what will get the job done and not have to redo it. What are my options?
Offline Jluck
  • 1389
  • 40
« Reply #3 on: June 23, 2011, 08:16:55 AM »
don't worry about having too much power, the VW TD's don't make anywhere near that kind of power. (even built ones).been there done that,and I have driven more than one. :)
« Reply #4 on: June 23, 2011, 10:43:19 AM »
K even when tuned I don't have to worry about snapping unless I do major rock crawling right?
Offline Jluck
  • 1389
  • 40
« Reply #5 on: June 23, 2011, 03:02:36 PM »
I cant say it will never happen but its just as likely with a sick 1.3 as a VW diesel. they don't make impressive power in a Suzuki. don't be shocked after dumping 5K to get the diesel in there that you still cant pass a Amish buggy.
« Reply #6 on: June 23, 2011, 04:59:21 PM »
Even with rock crawling it all depends on how your drive it.  I ran for years without breaking an axle with 33x12.5 on stock Sammy axles.  A buddy with lower gears and smaller tires would break his on a regular basis.
What size tires are you looking to run and what type of wheeling do you do?
« Reply #7 on: June 23, 2011, 09:06:16 PM »
Everyday driving and an occasional dirt trail. Looking a 32's or 33's
« Reply #8 on: June 28, 2011, 10:46:57 AM »
For that going to Toyota axles would probably be a waste.  Stock Suzuki axles will hold up without an issue.
« Reply #9 on: June 28, 2011, 11:27:42 AM »
Thank you very much Drone.
