OK stock size tires, so it's not a tire issue, yes the chatter at 5 cycles per
second is normal. If the O2 has been changed, then it could be defective,
and I have found them at times, or the timing could be off, also you could
have a slipped timing belt, that will also affect the timing and the engine will
run out of valve time which could cause poor economy
