90 tracker man. trans. shaft ??
  • 25 Replies
  • 4402 Views
Re: 90 tracker man. trans. shaft ??
« Reply #15 on: April 16, 2011, 09:01:03 AM »
Do you know what to torque the bolts on the pressure plate to?  I don't have a service manual.  I think I need to get one.
Clutch pressure plate bolts= 17ft.lbs.
flywheel bolts= 48ft.lbs.
Offline fireman2828
  • 26
« Reply #16 on: April 16, 2011, 09:16:36 AM »
Thanks, I appreciate that.  Just found this site that has all the info I needed. http://www.zookpower.ca/tech.html  Don't know how to make it a clickable link. I'm sure its been posted somewhere here before.
1990 Geo Tracker 4x4, 5sp.,
Auto locking hubs.
First tracker ever owned. Purchased 3/2011
Want a Samurai
Offline fireman2828
  • 26
« Reply #17 on: April 16, 2011, 09:29:13 AM »
Skyhiranger, you seem really knowledgeable about Trackers/Samurais. Glad theirs people like you on this forum.
Auto locking hubs.
Want a Samurai
Offline fireman2828
  • 26
« Reply #18 on: April 17, 2011, 07:28:15 PM »
When you instal the throw out bearing, do you loop the one side over pin and slide other side on and let it rest?  The shop took it off, and I didn't see how it goes.  Just want to be sure I did it right.
Auto locking hubs.
Want a Samurai
« Reply #19 on: April 17, 2011, 08:33:21 PM »
Yes.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #20 on: April 18, 2011, 08:59:25 AM »
The 16V trannys will interchange as well, but the 5th gear ratio is higher (lower RPMs at the same speed) than the 8Vs.
Skyhigh this is interesting. Any way to confirm this? A link to some tech specs would be helpful. ;D
I know my 1990 8v has a 0.86:1 5th gear (or 14% overdrive, depending on who you talk to). Curious about this because this would be a very nice solution to those looking for lower highway revs.
I also have a 1995 16v tranny sitting in a parts car...hmm >:D
« Reply #21 on: April 18, 2011, 09:14:49 AM »
I have confirmed it myself, several times.  Put the tranny in 5th, spin the OUTPUT shaft 1 revolution, note how far the input shaft turns (it will turn less than 1 revolution).  You have to mark the shafts and turn them very precisely, there isn't much difference between .795 of a turn and .86 of a turn.
Look for some trackick specs in FSMs or owners manuals, they will list the tranny ratios.  I believe there is an FSM on acksfaq.com that shows the tranny ratios and the one listed is .795.  Seems like it is for a 97 tracker maybe...can't remember for sure.
Offline djlantis57
  • 871
« Reply #22 on: April 18, 2011, 09:54:26 AM »
This would be a great upgrade. That would mean in my tracker, for example, that I could swap in 5.38s or 5.62s for a better crawl ratio in 1st gear, but regain my highway-friendly final drive ratio in 5th. I guess it would just depend on how much different that 5th gear is.
Hmmm you've really got me thinking about this now...
Offline Medford
  • 184
« Reply #23 on: April 23, 2011, 09:43:40 PM »
DJ; do the airbags first then this so you can tell me how to set mine up! ;D
96 Tracker LSI, 2.5" Pro Comp lift with cooper 30X9.5 STT tires.  A bit of trim and beating to make the front work.
« Reply #24 on: April 24, 2011, 07:36:36 AM »
The RPM difference at 70MPH is about 300, between the .795 and the .86 ratio.
Offline djlantis57
  • 871
« Reply #25 on: April 25, 2011, 12:39:08 AM »
Yup I know I know. You want me to get those bags done. School will be finished mid May. After that it looks like I'll have some old spare time.
