« Reply #5 on: June 05, 2012, 06:00:52 AM »
What Sky is saying is the transfer case from the later Sidekicks 95 ? 96 + had a 16 spline output shaft at the rear. the front shaft is the same as yours and your trans will bolt up to your xfercase.
![](https://www.zukiworld.com/forum/Themes/Studio/images/ip.gif)
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
