88 Samurai cold idle problem
  • 4519 Views
« on: February 05, 2011, 01:36:18 PM »
I purchased a 88 Suzuki Samurai last week. All stock, 87,000 miles, 40,000 were towed miles.
It runs great, very quiet, just one problem: It will not run when cold without holding my foot on the gas to keep it at 1500 rpm.
When it warms up, after 3 to 5 minutes, it idles perfrctly at 1000 rpm. All re-starts, as long as the engine is warm, are easy and it idles fine.
I am new to this and I have done the following:
cleaned the carb inside & out with carb cleaner
checked all vaccum lines for leaks and connections
replaced air filter
Any suggestions?
« Last Edit: February 05, 2011, 01:41:59 PM by tennrock »
Re: 88 Samurai cold idle problem
« Reply #1 on: February 06, 2011, 10:00:18 PM »
My zuki would start fine but choke would not open up after the engine warmed up. I now have it wired open and have to pat the gas pedal to keep it running until the engine warms up. So check your choke. When the engine is cold it should be closed and of course open as the engine temp rises.
« Last Edit: February 07, 2011, 11:34:01 AM by backwoods »
« Reply #2 on: February 07, 2011, 02:54:06 PM »
Thanks for the reply.
I took the intake case off and the choke is opening & closing OK with engine temperature, so now I assume I have a problem with the idle-up system.
When I cut on the lights & heater fan, the engine idles down just a little with the electrical load, not up.
The next thing I am going to check is the idle-up actuater and the three-way solenoid valve and connecting vacuum lines.
Does anyone have a source for the TWSV and idle-up actuator?
I'll post a update after the tests.
« Last Edit: February 07, 2011, 03:00:31 PM by tennrock »
Offline 02CalTaco
  • 196
« Reply #3 on: October 29, 2011, 12:40:31 PM »
Any update on what the problem was?
Offline dwebb11b
  • 37
  • If your gonna be original expect to be copied
« Reply #4 on: November 03, 2011, 09:35:29 AM »
i used to have choke probs after a float adj them i put in a manual choke.solved the prob.10 bucks amd 10 min.plus i have more control
Offline 02CalTaco
  • 196
« Reply #5 on: November 03, 2011, 12:41:53 PM »
Did you have to disable any smog related parts to make the manual choke conversion? I'm in Cali., if it dosnt interfere with passing smog I would be interested in get more info on how to do this.
Right now my choke stays open when cold, choke plate moves freely with my finger.
