Turning and hiting a bump noise
RACER X
383
zuki or die!
June 27, 2010, 09:41:14 PM »
If I turn and hit a small bump at the same time I get a clunk/poping noise from the front drivers side of my 98 kick Im leaning towards cv joint anybody got this prob or better yet an answer?
98 kick
beagle..t
1239
16
Re: Turning and hiting a bump noise
June 28, 2010, 07:43:20 PM »
frnt sway bar
V6 swap auto ,2 dr ,2" BL,2" jeffs kit 512 gears warn hubs and 30/9.5/15 BFG AT
RACER X
383
zuki or die!
June 29, 2010, 11:52:28 PM »
sway bar is disconnected up front
98 kick
TNTracker
37
Reply #3 on:
June 30, 2010, 06:44:16 PM »
I had one doing close to the same thing dont know for sure what yours sounds like, and about 6 months later the strut started leaking oil out around the piston. I got rid of it before i changed the strut but i am guessing thats what was causing it. All the ones ive had with bad cvs didn't make much noise until i put them in 4 wheel drive but i guess its possible, but you would think it would do it every time you turned even if you didn't hit a bump if it was a bad cv.
RACER X
383
zuki or die!
Reply #4 on:
July 03, 2010, 09:03:31 PM »
Hey thanks for the input anyone else got any ideas
98 kick
wildgoody
8134
67
Reply #5 on:
July 04, 2010, 08:49:12 AM »
What tires do you have?
Did you take the sway bar off or just loose?
Check the upper strut mounts for damage, I had one come
apart once, now I carry a spare
