87 samurai horsepower problems
  • 23 Replies
  • 5488 Views
Offline DMzuk
  • 18
« on: September 21, 2011, 09:14:31 AM »
Hi guys I have a 87 samurai with 69,000 miles on it that i know of. as far as performance parts go it has a full calmini exhaust with header and a drop in k&n filter and 6.4:1 tcase gears other then that its stock. I have been driving it around for the better half of 8 months with zero problems but now it hardly pulls 50mph in 4th gear on flat ground. ive been through the hole thing and the only conclusion i have is the engine is just tired.
i would greatly appreciate any input you may have.
Re: 87 samurai horsepower problems
« Reply #1 on: September 21, 2011, 09:39:01 AM »
A leak down test or compression test should tell you if the engine is getting at the end of it's life.  Did the issue just start one day or has it been a slow progression?
Offline DMzuk
  • 18
« Reply #2 on: September 21, 2011, 11:16:46 AM »
it started about a month ago and slowly got worse i though it just needed a tune up. so i put new a cap and roatter, spark plug wires and spark plugs and it ran fine for a while and then it was back the same.
Offline FBJR
  • 99
« Reply #3 on: September 22, 2011, 08:31:58 PM »
Does it have a cat? If it does check that it is not plugged, after the compression test that is.
Whats a "roatter"  ???
I think I had a motorcycle that was heavier!!
Offline DMzuk
  • 18
« Reply #4 on: September 27, 2011, 09:13:56 PM »
alright i finally did a compression test on my samurai and not one of the cylinders went over 90 pounds and the cam is starting to flatten out a little bit. Im kinda surprised that it was still running with such low compression.
Who makes the best master rebuild kit and would i benefit from a torquer cam at all?
Offline FinishTheGame
  • 139
  • Rabbit Hunter
« Reply #5 on: September 27, 2011, 09:22:51 PM »
If he is running a full aftermarket exhaust than the Catylitic convertor should be fine, you usually only have to worry about that if you have 100k miles+ on engine.
SJ-413   mild modifications
Offline airmanwilliams
  • 913
« Reply #6 on: September 27, 2011, 10:40:44 PM »
when and if you rebuild the motor be sure to get rid of the crappy carb for a myside harley carb kit. 8)
1993 4door Suzuki Sidekick JX
Offline talonxracer
  • 1284
« Reply #7 on: September 28, 2011, 06:46:59 AM »
The torquer cam usually moves the powerband down in the rpm range, thusly top end power will more than likely drop and the low/mid range gets a torque/power boost.
  • 139
  • Rabbit Hunter
« Reply #8 on: September 28, 2011, 07:43:27 AM »
I heard about the Harley carb from someone before, what brand is it.  I used to have a Suzuki cruiser and i hung with alot of HD riders, a couple of them used to run CV (constant velocity) Carbs, is this what you are reffering to?
  • 913
« Reply #9 on: September 28, 2011, 07:58:28 AM »
yup its a cv carb. zuksoffroad makes the kit to install it and myron is the best guy ever and answers whatever questions you have about it.
  • 139
  • Rabbit Hunter
« Reply #10 on: September 28, 2011, 08:01:42 AM »
I found also Peroworks kit, that comes with a better intake manifold:
http://www2.izook.com/?page_id=316
Offline DMzuk
  • 18
« Reply #11 on: September 28, 2011, 12:40:55 PM »
I wish i could put the my side carb kit on it but i live in California so it wont pass smog if i do.
Thanks for the help guys.
  • 139
  • Rabbit Hunter
« Reply #12 on: September 28, 2011, 12:47:49 PM »
NP.
That sucks, iv'e lived in Florida my whole life and we have very little driving regulations, no inspections or anything like that, just register your vehicle and your good to go.  I love it here, i would never move.
Offline FBJR
  • 99
« Reply #13 on: October 02, 2011, 06:50:33 PM »
Ca sucks with all its regs and they are getting worse, thats why so many are moving out.
A cat can plug up in a few hundred miles, new or not. When you loose power fast it is a good place to look just like the fuel filter.
90 psi means very little if they are all within about 10% of each other.
Offline DMzuk
  • 18
« Reply #14 on: October 02, 2011, 08:22:11 PM »
i took the CAT off and shined a light through it and it was clear.
 the only way i was able to get 90psi was by flooring it while i was cranking it over unless im doing the test wrong.
 what should the psi be at per cylinder? does anyone know?
