5:14-1 calmini t-case loud
pllssmith
12
July 06, 2010, 06:36:58 PM »
I HAVE CALMINI 5:14-1 GEARS IN MY T-CASE AND ONCE I GET TO 45 MPH IT STARTS GETTING A HIGH PITCH WINDING NOISE. AND IN 4WL IT GETS LOUD AT HIGH RPMS. I PUT ALL NEW BEARINGS IN CASE AND ITS ALWAYS BEEN THAT AWAY ALSO IVE CHANGED THE GEAR OIL 2 TIMES NOW ITS GOOD AND CLEAN NO METAL SHAVINGS. AND NOW IM TRYING LUCAS GEAR OIL AND ITS NOT HELPING NEITHER. ANY BODY HAVE ANY IDEAS?
Paul S.
wildgoody
8134
67
Re: 5:14-1 calmini t-case loud
July 06, 2010, 09:11:57 PM »
Sounds like a miss machined set of gears, they should make
some noise, but not as loud as you are describing
bluelabel1927
6
July 08, 2010, 05:24:24 AM »
+1 the amount of angle intersection of the gear is crucial. They will howl every time if not lined up just perfect.
mrhawk
130
I Love ZUKS
Reply #3 on:
July 12, 2010, 01:28:10 PM »
Same problem with my calmini gears. when I hit 60 the high pitch whine is brain piercing.
www.mrhawk.com
[/url]
bentparts
4536
60
I'd rather be Blown AND Injected.
Reply #4 on:
July 12, 2010, 02:24:32 PM »
I've got Calmini gears in my tracker tcase and they're noisy, but only in 4wd.
Drone637
8121
116
Evil Cow
Reply #5 on:
July 12, 2010, 05:54:42 PM »
Have you tried giving Calmini a call?
wildgoody
8134
67
Reply #6 on:
July 12, 2010, 06:09:43 PM »
I hate to say this but I'm glad I got Trial Tough gears for the Sidekick,
they are quiet like they should be, sure there is a little noise but I never
thought it was loud or even abnormal, low gears make a little more noise
just from being low
