Just a note, if you don't know: DO NOT engage 4wd on dry pavement, or even just wet pavement. It will torque lock the 4wd system & cause damage. 4wd needs a loose surface, ie dirt, gravel, sand, grass, snow etc. to allow it to slip a little to make up for the difference the wheels travel around corners. Hth.
Fuzz
