It sounds like you might be having issues with your differential
pressure or vacuum actuator, I can't remember which way it works.
Check the lines for leaks, or you can replace the actuator diff for a older
standard unit that does not require the actuator, and add the lockout hubs
to the outer where you have drive flanges now
