tranmission switch.
  • 1424 Views
tranmission switch.
« on: August 22, 2010, 10:33:14 AM »
i have a 1995 sidekick 16v with a 5 speed transmission that needs a rebuild, i also have a 93 sidekick 16v 5 speed with a good transmission. and i was wondering if i could switch the trannys with out any problems. i also am wondering if it would be easier to just drop the tranny, or to pull out the engine connected to the tranny.
Re: tranmission switch.
« Reply #1 on: August 23, 2010, 12:47:53 AM »
Swap away, they will interchange.
If the combo is too heavy, you could drop the T-case from
each so you can work easier
« Reply #2 on: August 23, 2010, 07:20:08 AM »
Great.
« Reply #3 on: August 23, 2010, 07:30:14 PM »
I would just drop the tranny and tcase out.  Pulling them with the engine might be kinda difficult.
« Reply #4 on: August 24, 2010, 10:22:42 PM »
Just an idea. 4 mount bolts, un plug this disconnect that. And the engines out. If removing an engine was that easy it woudnt be any fun.....
« Reply #5 on: August 25, 2010, 12:03:37 AM »
Well if you feel up for a ton-o-fun pull away  ;D
« Reply #6 on: August 25, 2010, 07:42:07 AM »
I have spare time, just not that much. Thanks for the help.
