What's the clicking sound behind my glove box? '90 Zuki
  • 1628 Views
Offline worrkshop
  • '90 Zuki Mini Monster
« on: May 09, 2011, 12:42:52 PM »
Hi, What's the clicking sound behind my glove box? I loose power, then it goes away. There's two relays back there but i don't know what they are for. Thanks!
  • 6554
  • 64
Re: What's the clicking sound behind my glove box? '90 Zuki
« Reply #1 on: May 10, 2011, 08:12:37 AM »
Fuel Pump and Main Relay... They are the same relay as what's in the Sidekick.. So, you can get some junk yard ones to test. The main relay comes on with the key placed into the 'run' position and the fuel pump relay will come on for 5 seconds when the key is placed in the 'run' position and then will come on during the 'crank' position and finally will stay on if the ECM thinks the engine is running.
If it's going click-ca-clickity-click... your ECM may need repair or battery is low or grounds/power cables need cleaned.
Hope this helps.
« Reply #2 on: May 17, 2011, 12:36:11 PM »
Yep, the main or fuel pump relay is clicking.  Could be the ECM going bad (most 90-95 samurai ECMs do eventually), could be a faulty relay (I have had that problem before), could be a bad wiring connection somewhere.
