What ATV do you use in Sidekick Automatic Transmission
sidekickyc
137
ZUKIWORLD Online!
April 13, 2016, 10:27:11 AM »
I have been using Dextron III in daughters 97 sidekick;
Is that what you've used or is/do you think, another type should be used?
Thank you
rasmeidirtrider
76
ZUKIWORLD Online!
Re: What ATV do you use in Sidekick Automatic Transmission
April 14, 2016, 05:54:26 AM »
I think Dexron III is ok. However, Dexron VI (6) is the current best fluid.
__________________
'96 (07/95) Sidekick Sport 16V, 1.8L, 4 auto, 4x4, 4dr, A/C, ABS, 99K on odometer.
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4 auto, 4x4, 4dr, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R/16.
fordem
4314
167
April 14, 2016, 06:05:06 AM »
Although newer fluids are supposedly backwards compatible, this is not always the case - Dex II/III is the recommended fluid and is still widely available, that would be my choice.
sidekickyc
137
ZUKIWORLD Online!
Reply #3 on:
April 14, 2016, 06:15:08 PM »
Thank you
