On my 84 sj410, I had a mechanic pull the tranny because 2nd gear would pop out of gear if you did hold the gear shift. He replaced a bearing. Now it seems the suzuki can only be placed in 4wd, not 2wd. It worked perfectly before he touched the tranny. He says since its a divorced tranny and transfer case, he didn't touch the transfer case, it's not his problem. What are your thoughts?
