Dash swap
  • 16 Replies
  • 2904 Views
0 Members and 18 Guests are viewing this topic.
Offline ridgerat4x4
  • 30
Re: Dash swap
« Reply #15 on: August 31, 2011, 05:05:11 AM »
So you are saying the ecm gets its speed signal from the speedometer in the dash instead of a speed sensor directly at the t-case I found most of the wiring on acks that looks to be a useful site and what does it use the speed signal for locking up the converter? Just wondering the 98 is only has one o2 sensor in it but somebody stole the cat off it before I got it I never thought to look for wires is there suposed to be two o2s on it
« Last Edit: August 31, 2011, 05:11:03 AM by ridgerat4x4 »
my crazy junk ,77 M35a2 duece and half,86 dodge long bed on 2.5 tons (under construction), 98 tracker, 91 dodge diesel
Re: Dash swap
« Reply #16 on: August 31, 2011, 08:08:22 AM »
I do not have a 98, or a FSM for one, but the 95 still has the speed sensor to ECM coming from cable driven speedo.  I know the 2003 uses electronic sending unit at transmission, and thought the model switch in 2000 was probably when they changed.  I have wedged an electronic speedo into my 93, so you can do creative things to make it work.
You would have to check the FSM, or find a 98 same model to compare.  Or a member may chime in.
