'96 16V camshaft sensor in distributor
  • 1176 Views
Offline one mile
  • 174
« on: September 17, 2016, 06:32:49 PM »
Prices and brands all over the place, but I need to know from you all which is the best brand to buy and what I should expect to pay.
"WORK SMART NOT HARD"
Offline one mile
  • 174
Re: '96 16V camshaft sensor in distributor
« Reply #1 on: September 18, 2016, 10:54:23 AM »
The code I am getting is po340
Offline one mile
  • 174
« Reply #2 on: September 18, 2016, 07:22:41 PM »
What I see is a SZ04 distributor Spectra Premium brand for $ 157.98 . I have also seen a SZ04 and SZ08. I am now confused. I have a '97 16 Valve motor. Which on do I get ?
Offline fuzzy1
  • 350
« Reply #3 on: September 20, 2016, 10:24:19 AM »
I'd be more suspicious of the wires than the CPS itself.
Have you had any 'no crank' situations/problems recently. I just had my starter go bad, & after one of the no cranks it threw a P0340. After checking fuses, wires, & relay, I used the oldschool 'bang the starter with a hammer!' method & it started right up! :p I cleared the code & since then had the starter replaced & the code hasn't returned.
I'd check the wires to the dizzy & test them for continuity before replacing the dizzy itself.
Non Illegitimi Conterat
« Reply #4 on: September 21, 2016, 01:10:09 PM »
If the ECU doesn't see an input from the CPS when the starter has been engaged for a period of time it can throw a CPS error, if the engine isn't actually turning then a false code is possible.
Offline one mile
  • 174
« Reply #5 on: October 04, 2016, 06:50:10 PM »
Ended up putting new distributor in and it runs great ! Thanks for all the input ! Tim
