gear ratio on a 1987 Samurai
  • 1984 Views
Offline retire
« on: January 12, 2023, 02:45:26 PM »
Can anyone tell me what the standard gear ratio on a 1987 Samurai would be and also if someone says the vehicle has 462 gears does that mean the ratio is 4.62? Thanks
  • 4320
  • 167
Re: gear ratio on a 1987 Samurai
« Reply #1 on: January 12, 2023, 03:56:32 PM »
Stock axle gears are 3.73:1, if it has 4.62:1 gears they came from a Sidekick.
Online Dughrt
  • 37
« Reply #2 on: January 13, 2023, 11:39:14 AM »
Don't you need a hybrid rear axle in order to run sidekick gears in a samurai?
  • 4320
  • 167
« Reply #3 on: January 14, 2023, 06:24:14 AM »
I'm not certain I understand the second question - what does how the gears were fitted have to do with it?  Samurais didn't ship with 4.62 gears, and the most common source of 4.62 gears is a Sidekick - whether you use a hybrid axle or not (I believe there is more than one way to do it), if you have a Samurai with 4.62 gears, there's a 99% probability they are Sidekick gears.
Online Dughrt
  • 37
« Reply #4 on: January 16, 2023, 01:44:05 PM »
 Sorry for the confusion. I was always under the belief that sidekick gears did not fit into the samurai center section and so you needed a hybrid axle that was made with a larger center section (from a sidekick) in order to house the sidekick gears. If I am mistaken that would save me a lot of hassle when I go to switch mine over.
  • 4320
  • 167
« Reply #5 on: January 16, 2023, 02:51:34 PM »
I've no personal experience but I was of the impression it was a matter of bolting the Sidekick ring & pinion onto the Samurai center and adding a "can" to prevent the cross pins from walking out.
The thread below lists a couple of different ways to do it.
https://bbs.zuwharrie.com/content/topic,3177
« Reply #6 on: February 03, 2023, 05:40:23 PM »
Rear trackick gears do not fit samurai axle housings. But 2 sets of trackick front gears will fit both the front and rear samurai axle housings.
