Transmission
  • 1149 Views
Transmission
« on: October 07, 2011, 08:05:42 PM »
I have a spare transmission for my 86 that i think needs to go in due to my current transmission making noise, before i put in the new / old transmission is there anything that i should look for or do before i make the swap?
Re: Transmission
« Reply #1 on: October 08, 2011, 11:58:10 AM »
Would be a good idea to go through the replacement trans to
make sure you don't have to replace the transmission twice  ;)
Re: Transmission
« Reply #2 on: October 08, 2011, 05:01:17 PM »
when you say go through can you be specific on what you mean? my knowledge of transmissions is not the greatest!
Offline FinishTheGame
  • 139
  • Rabbit Hunter
Re: Transmission
« Reply #3 on: October 08, 2011, 05:56:14 PM »
Buy a factory service manual, go to the 'transmission" section, then go through and check bearings and synchros and gears etc.... the book will tell you in detail how to do any kind of service or rebuild (tear down and reasemble).
SJ-413   mild modifications
