I recently replaced bearings and seals in my 87 Zuk transfer case, front output shaft bearing was bad, would not go into low range before the rebuild. Bench checked by operating input from tranny using impact, everything shifted great and went into all ranges. Installed in my Zuk and test drove, still would not lock into low range, it feels like the shifter will not go all the way, a buddy where I work had the same problem, he removed his shifter and used a torch to heat the shift handle and bent it back, he says it works fine now. Just wondering if anyone else had the same problem and this is the right fix.
Also installed 1999 Mustang seats, they work great.
