XL7 Body and suspension lift
  • 7714 Views
« on: January 29, 2010, 02:05:18 PM »
I am looking to lift my 02 XL7.  My plan is to do a 2 inch body lift and coil spring spacers for another inch or so.  Are the coil spring spacers and strut extensions the same from sidekick?  I noticed several people here have used the master kit body lift.  Has anyone used a body lift from the sidekick? The Masterkit seems pretty spendy.  I do not need bumper brackets.  I am going to build custom bumpers.
How about camber adjusters?  Are these purchased from a local auto parts store or from  specialized vendor?
I am also wondering about the steering column spacer. I havent seen any talk about this.  Is it needed with a 2" body lift and what can I use?
Offline jeff1997
  • 1228
  • 27
Re: XL7 Body and suspension lift
« Reply #1 on: January 29, 2010, 06:27:44 PM »
My coil and strut spacers work on the XL-7 for a full 2" all around.
3" Masterkit1 body lift
Custom strut spacers
« Reply #2 on: February 01, 2010, 11:57:16 AM »
Two inch spacers on the struts seems like a lot to ask of your CV's.  Do  you have any trouble with the CV's breaking?  I want to keep mine very dependable and the handling close to stock if possible.  Its my wifes grocery getter.
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: February 01, 2010, 12:00:18 PM »
The front uses 1.5" spacers and the rear 2". This gives you a full and even 2" lift all over. I ran this same setup for 4 years with no issues. It was also my DD. The handling does not change.
Offline paulyxl7
« Reply #4 on: July 18, 2011, 10:09:56 AM »
Do you have to do any thing about the rear track bar
Offline MUD CHILD
  • 355
  • 9
« Reply #5 on: July 18, 2011, 12:15:16 PM »
Yes the track bar (pan hard) should be relocated to sit flat like it was riginally or the truck will not handel the same. Here is a link to the 4" combe kit I make:   http://www.srcustoms.ca/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=30&category_id=8&option=com_virtuemart&Itemid=56
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
« Reply #6 on: July 22, 2011, 11:07:29 AM »
I still havent got around to lifting my XL7 but here it is with new 235/70/16 tires.  They dont rub during normal driving and no trimming was necessary.  They rub the upper strut mount on a hard bump.
