lift shocks
  • 10 Replies
  • 3195 Views
Offline bush buster
  • 263
lift shocks
« on: February 06, 2012, 05:07:35 AM »
I was wondering what you guys with lifted xl7's are using for rear shocks?  Because I put xl7 springs in the rear of my vitara and the mustang shocks I that are on there now just can't handle them.
Offline bush buster
  • 263
Re: lift shocks
« Reply #1 on: February 14, 2012, 10:25:22 AM »
What nobody on here has a 2" suspension lift in their xl7?? Bunch of soccer moms :P
Offline samuraidan
  • 196
    • City Ranger
Re: lift shocks
« Reply #2 on: February 16, 2012, 04:14:39 PM »
bump.
i'm curious too. my crown vic shocks are all but blown and i'm looking to upgrade to xl-7 springs along with my spacer, while im doing that might as well replace the shocks.
because the xl-7 springs are taller, the shock would need to be longer right?
Offline bush buster
  • 263
Re: lift shocks
« Reply #3 on: February 23, 2012, 12:27:21 PM »
I think the length seems ok on the mustang shocks since the xl7 springs only yield about 3/4" lift.  But my new shocks are definately trashed after about 6 months. Whats worse is I just noticed that one of my xl7 springs is sagging already, i assume from running blown shocks with heavy loads.  I took out one of the rear seats to make a cargo bay but now that side is sagging ffs.  I think this would not have happened with some stiffer shocks to protect from bottoming out although the more noticeable issue is topping out.  The Xl7 springs are a great upgrade though, especially if you're pulling a trailer or heavy load.
Offline samuraidan
  • 196
    • City Ranger
Re: lift shocks
« Reply #4 on: February 28, 2012, 12:55:57 PM »
If topping out is an issue, wouldn't longer shocks help solve that?
If i can find some XL-7 springs, i thin i'll just try another set of Mustang shocks. Best thing about 'em is they're cheap. I think i paid $60 for two last time i got them.
Offline samuraidan
  • 196
    • City Ranger
Re: lift shocks
« Reply #5 on: March 02, 2012, 02:40:14 PM »
bush buster, pm sent
Offline ktec
  • 24
Re: lift shocks
« Reply #6 on: June 24, 2016, 08:01:06 AM »
Rocky road off road makes a custom set of rear shocks for lifts over 1.5".
or OME for up to 1.5"
2006 XL-7 4wd
Offline ktec
  • 24
Re: lift shocks
« Reply #7 on: August 18, 2016, 09:02:58 AM »
Could anyone who has a Rocky Road or OME lift for XL-7 comment on rear shocks please?
  • RRO website and one rep on phone stated the kit comes with their own design rear shocks.
  • I order the 2"+ lift kit from RRO and they say they are sending OME N105 shocks.
  • OME catalogs N153 for XL7 and N105 for Grand Vitara
SPECS
MODEL. OPEN LENGTH (mm) : CLOSED LENGTH (mm).
N105 - 508 : 318
N153 - 528 : 312
What is going on?
« Last Edit: August 18, 2016, 09:29:15 AM by ktec »
2006 XL-7 4wd
Re: lift shocks
« Reply #8 on: August 19, 2016, 11:29:10 AM »
I am running Excel KYB's, and they may be stock for the tracker.  I do run limiting straps to keep springs in place, and have bump stops to prevent shock bottoming out.  Using the shocks to limit travel either up or down will shorten their life quickly.
I have raised the bottom shock mount to keep it from hitting on rocks, and modified it so the bottom mount bolt is length ways with the Tracker.  That allows it to rotate when stuffing wheels offroad.
Offline olija
  • 770
    • Check out my cardomain
Re: lift shocks
« Reply #9 on: December 31, 2016, 11:09:14 AM »
According to Boondox Motorsports website:
Procomp ES1000 series shock absorbers provide great performance and value. The narrow profile will not interfere with Suzuki lower shock mounts like larger body shocks will. Includes black boots. Sold in pairs.
'89-04 Sidekick/Vitara 0-2" Lift
EXP-120510-20RS          $70.00
'89-04 Sidekick/Vitara 3-4" Lift
EXP-122510-40RS          $70.00
'89-04 Sidekick/Vitara +4" Lift
EXP-124510-45RS          $70.00
I'm pretty sure those will work. The shock mounts on my 03 XL7 looked exactly the same as my friend's 04 Vitara.
Offline ktec
  • 24
Re: lift shocks
« Reply #10 on: December 12, 2017, 12:27:47 PM »
interesting find.  I wonder which model works best for a ~2" lifted XL-7 and if shock length specs are anywhere to be found.
Thanks!
2006 XL-7 4wd
