XL-7 rear door wheel cover???
  • 9 Replies
  • 2949 Views
Offline Superzuki
  • 8
  • 2003 XL-7
« on: January 09, 2006, 05:54:09 PM »
i saw this in a forum and i was wondering if anyone knew where i could get one of these spare wheel covers?
i sent a message to rc211e2 (who posted that picture) but got no reply :'(
can someone give me some info please?
-SuperZuki
2003 XL.7
Yakima Loadwarrior on Suzuki crossbars
Calmini 2.5" lift with OME Springs and Front struts
235/70/16 Yokohama Geolander AT+II's
Offline blacknight
  • 987
    • Gonzookin
Re: XL-7 rear door wheel cover???
« Reply #1 on: January 10, 2006, 04:59:04 AM »
I've seen 99+ Trackers with that cover in the US but no Zuki's.  May be try give Hawk a call and see if they have it or can get it.
George
Offline sergi
  • 307
« Reply #2 on: January 10, 2006, 06:34:30 AM »
They are standard in Europe. Mine has got the same. Maybe your Suzuki dealer can get it for you ::).
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: January 10, 2006, 04:00:45 PM »
Oooh, I like that.  How's it mount to the tire?
Been wondering what to do since we put the bigger tires on.  The vinyl cover won't fit by a long shot.
Offline sergi
  • 307
« Reply #4 on: January 11, 2006, 12:42:45 AM »
It's fixed by one bolt. What you see from the outside is something like a lock, you have toput the key in to remove that part. Under that there is a bolt, which holds the wheel as well. As the hole is not in the middle, the cover is always the right way up, as the cover has a lip that fits inside the rim (hope this made sense). Then you can remove the cover and you have 2 remaining bolts holding the wheel.
I can take pics tomorrow ;)
Barcelona, Europe
Offline sergi
  • 307
« Reply #5 on: January 12, 2006, 08:07:14 AM »
This is how it looks:
This is what remains when the wheel is removed. Ithought the bolt holding the cover hold the wheel too, but they are separate. The cover needs this black bracket:
These are the parts. The cover is part number 728G-65D, or at least that is what it says on the back. There is the bolt holding the cover and the theft lock thing:
Barcelona, Europe
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: January 12, 2006, 03:15:36 PM »
Thanks man, I'll see if I can get them here and around what they run. 8)
Offline Superzuki
  • 8
  • 2003 XL-7
« Reply #7 on: January 14, 2006, 08:10:37 PM »
thanks for the pics sergi ;D one question, does your zook have 15" rims? i have a limited XL.7 and 16s so id like to know if it would fit thanks for your help ;)
-SuperZuki
2003 XL.7
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: January 14, 2006, 09:28:36 PM »
He's mentioned before it has 16's.  I don't think Suzuki used anything smaller than 16's on GV's and XL7's anywhere.
Offline sergi
  • 307
« Reply #9 on: January 15, 2006, 03:23:02 AM »
16" rims, like all GVs ;)
Barcelona, Europe
