ring and pinion question
  • 1378 Views
« on: January 21, 2011, 12:51:38 PM »
ive got a spool in the rear on one of my trackers and im wanting to put it i the front of another tracker i got will it work
Re: ring and pinion question
« Reply #1 on: January 26, 2011, 05:34:36 PM »
If you have a 96 and up Tracker, yes.  If not then no, you need the larger splines up front.
« Reply #2 on: February 09, 2011, 02:01:15 PM »
Ok another question are the ring and pinion the same size front and rear on a 94 and down I know the carriers are different but they look the same
« Reply #3 on: February 10, 2011, 12:43:17 PM »
You will probably want to swap over to a Samurai third member in order to get the steel diff.  The main difference is the 96 and up have the larger splines that come with the mini-spool.  It's sort of like how you have to switch to heavy duty axles to run a mini-spool up front on a Samurai.
« Reply #4 on: February 10, 2011, 02:29:53 PM »
The ring and pinions are not the same size front to rear.
« Reply #5 on: February 11, 2011, 06:09:42 PM »
Oh, yea.  That as well.  I was just thinking about the mini-spool.  :)
