p0400 code egr flow
  • 9 Replies
  • 2463 Views
p0400 code egr flow
« on: October 12, 2011, 05:07:37 PM »
ok,need help with the code,i clean all lines,takeout egr,change actuarors,and still the code,but i have a question,in the exhaust side the car have a port that i need to clean ??? ???any help plz thanks
Re: p0400 code egr flow
« Reply #1 on: October 13, 2011, 08:23:41 AM »
What year vehicle? 16 valve or 8 valve?
This might sound basic, but are you sure all of the vacuum lines are hooked up correctly? I had EGR issues on my '95 Sidekick (16V), and noticed that one of the vacuum lines had simply fallen off.
- Andy
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Offline ranger88den
  • 279
  • 12
« Reply #2 on: October 13, 2011, 09:23:36 AM »
On the exhaust side there's a passageway thru the head and cast into the exhaust manifold.  Blow compressed air into both sides of the EGR valve mount opening and see if ift backfeeds (indicating clogged).  As Warn said, check vacuum lines and VSV operation also
« Reply #3 on: October 13, 2011, 01:21:39 PM »
sorry guys i forgot,the thuck is a 96 16v engine,all stock,the car been parked for almost 2 years when i buyed 132000 miles
« Reply #4 on: October 14, 2011, 11:42:13 AM »
Did you have the code cleared, once you did all that?  If not, then it may take awhile for the code to go away on its own.
Yes, there is an EGR passage from the exhaust manifold to the EGR valve.  That needs to be cleaned too.  You should be able to clean it by removing the EGR valve, sticking a wire in the hole and working it around until you get the build up broke loose.  You can also use brake cleaner or carb cleaner and compressed air to aid in getting the build up cleaned out of that passage.
« Reply #5 on: October 14, 2011, 04:39:27 PM »
ok that mean i need to take out the exhaust manifold or not,or just from the egr side
« Reply #6 on: October 14, 2011, 06:55:48 PM »
You can try it from the EGR valve side.  Then if you think you need to clean it better, you can pull the exhaust manifold.
« Reply #7 on: October 14, 2011, 10:09:46 PM »
thanks i apreciated all the imputs,i will post later need to fix that,the mpg killing me,again thanks
Offline ranger88den
  • 279
  • 12
« Reply #8 on: October 15, 2011, 05:20:35 AM »
Every 16v exhaust manifold I've removed had the EGR passageway clogged with carbon.  Just my experience.  BTW, every 16v exhaust manifold I've ever seen was cracked between the 3rd and 4th runner, even if only a barely visible hairline crack.  Anyway, good luck with your project.
Offline BeercityTracker
  • 40
« Reply #9 on: October 28, 2011, 02:37:23 AM »
when i bought my 98 it had an egr code, previous owner replaced every part on the system, i bought a can of brake clean and a throttle body gasket cleaned the port from the egr tube to the intake manifold and never had a problem, i was stumped at first because it was so clogged that i couldnt even see it from the throttle body side.
