I don't know if it will help you all that much, but I'm in the process of swapping a '93 4-door body onto a '98 frame. I'm also swapping over all the wiring and the dashboard so that I can have airbags (that, and all of the '93 HVAC stuff was full of mouse nests while the '98 parts are pretty clean). There are a few differences in the bracketry, but for the most part it seems like the major mounting points are the same. The bracket on the firewall that the steering column mounts to is different from the '93 to the '98, so I used a spot weld cutter to remove the '98 piece and welded it to the '93 firewall - nothing major, it was very easy to locate on the '93 sheet metal as the stampings (of the firewall) are pretty much identical. <--- if that sentence isn't clear, don't worry. It will be once you get everything apart and take a look at it.
Basically, it's not a 100% straightforward swap, but shouldn't be too difficult if you can cut and weld a couple small pieces.
