nice rig did you extend the rear? if you did how. did you extend the front? thanks
Thanks..
No it's not extended front or rear. I trimmed a lot out of the front fenders, probably a good 4 inches at the back-bottom of the fender and radiused from there to meet at the top of the arch. I also had to massage the floorboards a bit to stop rubbing. I'm sure at full-stuff and turned to lock, it'll probably still rub a good bit. Haven't had much chance to go offroading since the last set of mods
, so not sure how bad.
The rear hasn't been trimmed at all. I did roll the fender lip under to stop it from eating my tires at full stuff. It would look better to trim the front of the rear fender a bit, as the tire is close there, but when the suspension cycles, it actually moves away from that area, so I didn't worry about it.
That being said, I'd prefer it was stretched just a bit (about 2" front and rear) and when I go SAS, I'll do just that. The rear is a pretty simple affair. Extend the links, move spring pads/shocks, and stretch your driveshaft. Me personally; I'll more than likely go to leafs front AND rear because it's cheap, DIY friendly, stupid simple setup that will get me plenty of flex for what I want to do.
