6" lift with 32" tires?
  • 9 Replies
  • 3313 Views
« on: October 07, 2012, 02:34:25 PM »
im thinking about putting a 6 in lift on a smai and was wondering if i do go bigger tires do i kiss my wheel bearings goodbye as well as other problems?
Offline mrfuelish
  • 2862
Re: 6" lift with 32" tires?
« Reply #1 on: October 07, 2012, 05:34:34 PM »
it depends on your off set and how heavy the wheels and the tires are, boggers are over 100 lbs a tire with a steel wheel and can break just about any rig, if you go with  bfg all terrains with a set of weldwheels you would be ok up to a 35 inch I would think.
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #2 on: October 08, 2012, 08:06:46 AM »
I have about a 6-inch lift (TT YJ SPOA). I have been running it primarily as a DD for about four years. For about 3-1/2 of those years, I ran 31x10 with 8-inch wide wheels  with a 2-1/2-inch Back spacing. I had no bearing issues at all. I now run 30" Cooper STT on the same wheels.
I struggled with the idea of going to 32 or 33 tires, but decided on the 30s. I have seat of the pants more usable power with the 30s over the 31s, and there really is not that much difference in diameter. There is about 5-pounds per tire more weight with the 31s. I am glad I went with the 30s. The larger the tire, the more power to turn them, more gearing required, the more critical the allignment, harder to steer, more braking rto stop, vibrations are exagerated, more difficult to have good road manors. For a trail only machine, not too bad.
Wayne
'91 EFI, DD, Hardtop, A/C, Warn 8000 winch, 100 AMP Alt, Toy Celica P/S, TT YJ SPOA M/L, DT 8000 shocks, TT Knuckle Over Steering, Mighty Kong, 4:1 TC, Evil Twins, TT Full Skid, Diff Guards, Fuel Tank Skid, Sliders, Anti-Wrap Bar w/Axle Truss, Panhard Bar, Cooper SST - 30x9.5x15 , 8"x 2-1/2" BS wheels Maxima rear Disc w/ebrake, rear locker
« Reply #3 on: October 08, 2012, 08:59:48 AM »
is that pic of your samurai have a 6" lift with 30" tires?
i really like the stance of it...thats about exactly what im looking for!
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #4 on: October 08, 2012, 10:36:47 AM »
My lift is the Trail Tough YJ SPOA (http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=36&category_id=7&option=com_virtuemart&Itemid=53) about 6-1/2" lift, with four used 5-leaf YJs. I have 30" Cooper STT tires with 8" wide wheels and 2-1/2" back spacing.
Absolutely no rubing issues, excelent road manors.
Offline jcowdin
  • 111
« Reply #5 on: October 08, 2012, 12:37:21 PM »
Really nice rig!   :)  What bumpers are those?
The Price is Right!
Offline Reddog1
  • 106
  • 1991 EFI
« Reply #6 on: October 08, 2012, 01:14:41 PM »
Both are home fabricated, from scrap and junk.
The front is primarily a jeep bumper that hit a concrete wall on the freeway. I cut it apart, salvaged usable pieces, added other scraps. This photo is before moving front license plate an finish paint.
The back bumper is previously used 2"x4" tubing, parts from a riding lawn mower deck, and miscellaneous steel scrap.
Offline jcowdin
  • 111
« Reply #7 on: October 08, 2012, 01:21:01 PM »
Both are really nice!  I like the design of the rear, how the tire drops down.
The Price is Right!
Offline mrfuelish
  • 2862
« Reply #8 on: October 08, 2012, 01:50:53 PM »
if the tire was mounted on the other side it would make a good table.
Offline BLOODBANE
  • 144
« Reply #9 on: October 08, 2012, 08:28:38 PM »
I have a 6" SPOA and run 32's....
Mines the white TT. I have had this built this way since this last spring and I use it as a DD. I haven't found any weird during normal maintenance. One thing you haven't mentioned is what gearing are you planning. The 1.3 is really lacking when you go bigger tires. I put in a 6.5:1 case and love it. I also plan on dropping the R&P. I live in the rocks though, so super slow might not be your thing, but you will need something .
84 Ranger/6" lift/347 stroker/C-6/35"Boggers/lockers F&R-94 Explorer/7"lift/35'BFGs/lockers F&R/87 Samurai 6"SPOA,6.5:1 T-case, soon 1.6 16v,32" Pro-Comp MT's.
