1.3 on an a electric fan, no shroud(may make one soon) new aluminum radiator, new 160 thermostat. Ive check and water is flowing with cap off at 160 so the water pump seems to be working. Timing is set at 10 degrees. I heard that with the weber carb if it was running lean it would make it run hot. Also if i have a vacuum leak i would run hot as well. It runs around 190-200 on the road in 2x4 but when i put it in 4x4 in first gear it shoots up and up. Do you think that its an air flow issue or... Was hoping someone here has had the same problem and could help me out.
