Replacement carbs for 1.3a '87 Samurai
  • 9 Replies
  • 4437 Views
Offline Gotbait
  • 19
« on: September 29, 2011, 05:43:34 AM »
Is there any recomended replacement carbs for the 1.3l.  I would like to just go to a pick n pull yard and get a carb, or is that a bad idea.  I live on the coast and just plan on using my zuki for the beach.
Re: Replacement carbs for 1.3a '87 Samurai
« Reply #1 on: September 29, 2011, 03:52:29 PM »
I have seen a couple of conversions, but you will need to have someone custom build you an adaptor.  The most common swaps are to Harley CV carbs and a Webber.
« Reply #2 on: September 29, 2011, 08:23:41 PM »
Im currently swapping my stock carb for a Toyota corolla carb its a bit bigger cfm wise. It's bolt on and you can get em for cheap at local salvage yards, and they are vacuum line eliminators!!! They are amazing and I will post how I like it after I'm done with it. Zack "Team aftermarket4x4"
Offline Gotbait
  • 19
« Reply #3 on: October 03, 2011, 05:54:11 AM »
Super, what year?  That sounds like it would be worth a try.  Thanks!
« Reply #4 on: October 03, 2011, 06:45:43 AM »
Mine came off a 1988 corolla, google Toyota carb swap samurai. This is the easiest carb swap ever! I'm pretty sure mine came off an 88 I bought it off a buddy of mine.
Zak
Offline ebattleon
« Reply #5 on: October 19, 2011, 09:19:35 PM »
Toyota corolla carbs are good swap option just bolt it up and volia it even allows you to use the original air breather. I have one in mine and it runs ok. I had a Weber in the past good power but drank gas and had the infamous stall issues at high angles.
What is wrong with the current carb? I am guessing the main butterfly valve shaft is badly worn and you are having idling issues. In that case just have the shaft rebuilt and the bores re-bushed with delrin or brass. Follow that up with a carb kit and you fixed for another 100 000km.  I have found the original carb works best but that just my opinion.
Common Sense Absent
Offline Gotbait
  • 19
« Reply #6 on: October 20, 2011, 07:10:00 AM »
I was looking for a better power option.  I guess I reallly need more top end speed to be able to drive the zuki to work once in awhile.  Existing carb seems to be working fairly good I do think it could use all new vacume lines.
« Reply #7 on: October 21, 2011, 07:55:04 PM »
With that Toyota carb I have way more top end power and it's super simple to hook up! I did a few ditch runs and had no problems with high angles it didn't load up or stall. I love that carb!
Zak
Offline CALMINI_Inc.
  • 104
  • The Leader in Suzuki Offroad
    • CALMINI Products, Inc.
« Reply #8 on: November 08, 2011, 04:26:56 PM »
The EMPI and Weber units are just about identical.  Both are available in 32/26 and 38/38 configurations and have electric choke options as well.
With the float adjusted to 1mm of travel, offroading and hill climbs should be no trouble.
Offline woobr1
« Reply #9 on: November 09, 2011, 09:47:55 PM »
