Water leak..cant find it! *help*
  • 18 Replies
  • 5287 Views
« on: August 12, 2007, 10:21:32 AM »
Im going crazy! The problem is that my GV leaks water in heavy rain.
I cant find out where its coming from!
The carpet on the drivers side always gets wet. I´ll try to explain where i think it comes from.
It´s the drivers side front corner...About where you would rest your left foot while driving... where the fuse box is..
It´s like it comes down there and goes under the carpet
Has any one had this problem or even have a clue?
Offline MikeGV
  • 14
Re: Water leak..cant find it! *help*
« Reply #1 on: August 12, 2007, 11:39:32 AM »
Have you checked the radiator fridge ??? ??? ???
« Reply #2 on: August 12, 2007, 03:34:33 PM »
Isnt that just in cars with A/C? Becouse im in Iceland..and belive me I dont have or need it ;)
Offline MikeGV
  • 14
« Reply #3 on: August 12, 2007, 05:23:16 PM »
Nope ...
You've got one , and i believe it's time to change it  ;)
« Reply #4 on: August 12, 2007, 06:32:52 PM »
where is the radiator fridge? Any pics?
Offline MikeGV
  • 14
« Reply #5 on: August 12, 2007, 07:19:05 PM »
It is located near the center under the dash , in order to gain access you have to remove the instrument panel . It is a pain in the as :-X . Sorry i have no pics to help you . But in my opinion only a service manual would really help   ::)
Offline IanL
  • 466
« Reply #6 on: August 13, 2007, 12:51:23 AM »
Does you mean the heater matrix?
Why should water leak from that only when it rains?
« Reply #7 on: August 13, 2007, 01:06:37 AM »
It leaks only when it rains, the car stands still in the parking lot not even running
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #8 on: August 13, 2007, 08:27:53 AM »
Off hand, I can really only think of two places where there are holes in the body to the outside in that area.
1) In the door jamb near the hinges, there's a connector for the door wiring (power windows/locks/mirrors/speaker).  Check that and make sure it's fully seated.
2) The firewall has holes for the steering column, brake plunger, clutch, cruise cable, etc.  Check to make sure all those are secure.
Otherwise, the seal around your windshield could be leaking, I suppose.  Open the hood and have someone hit everything in the area with a garden hose, pull the carpet back and see where the water runs.
« Last Edit: August 13, 2007, 08:31:28 AM by beercheck »
XL-7 front coils
1.5" rear coil spacers
« Reply #9 on: August 13, 2007, 11:22:20 AM »
Thats a Great Idea...I´ll try that  ;D
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: August 13, 2007, 02:32:06 PM »
If I remember right there's an issue with these things and the fresh air ducts.  They fill with crap, the drains plug, and rain water, etc backflow into the heating ducts.  Might want to try and see what's in the air ducts...
Also try your windshield seals...my Tracker's are pretty gnarly looking and I'm sure that's where the water is getting into my cab from.
Offline benzr2
  • 72
« Reply #11 on: August 13, 2007, 04:03:25 PM »
I agree with AJMBLAZER, I have seen this happen on vehicles before
2001 Tracker ZR2 235/75/15 ATs       1987 Samurai Tin Top     New Project!!
« Reply #12 on: August 14, 2007, 05:41:10 AM »
You mean the duct infront of the windshield? :)
Offline benzr2
  • 72
« Reply #13 on: August 14, 2007, 07:44:51 PM »
Yes, it gets built up with leaves dirt and trash and clogs the drains. It may have have had water in it and froze then cracked ???
« Reply #14 on: August 15, 2007, 05:51:15 AM »
I think i found it...
The previous owner but á power cable through the firewall...through a little rubber hole...but he didnt seal it..it think when the water runs down the firewall it stops on the cable and runs through...
I sealed it and im going to spray water on it tonight and see if any water comes through...
Thanks for all the AMAZING help you guys!
