Tire Pressure
  • 28 Replies
  • 5467 Views
0 Members and 16 Guests are viewing this topic.
Offline 2K1USGV
  • 218
Tire Pressure
« on: April 29, 2006, 11:25:41 PM »
Just wondering what tire pressure everyone is running. I know the stock tire pressure is supposed to be 26PSI all around, but what about aftermarket tires? Different sizes?
Re: Tire Pressure
« Reply #1 on: April 30, 2006, 06:31:08 PM »
I, Personelly, Run 25lbs front and rear for D.D.
Thats on 2dr and 4dr with 32"s
Offline 2K1USGV
  • 218
Re: Tire Pressure
« Reply #2 on: April 30, 2006, 06:40:20 PM »
Yeah, I'm aired down to 26psi, I checked what it was because the ride seemes really rough with my new tires and the tire shop had it up to 38psi on my 10 ply 245/75/16's.
Offline willhl
  • 41
    • Will's Photography
Re: Tire Pressure
« Reply #3 on: April 30, 2006, 07:57:37 PM »
I run 36psi, need to get a compressor so I can air down off road.
36psi is what the tyre place recommended, it is also what was recommended when I did a driving course (emergency braking etc for on road).  My understanding is that the tyres will contact the ground better and clear water better, the added bonus of better fuel economy is handy too.  I'm just running standard sized Bridgestone Dueller A/T D694.  Once off road I've heard people recommending pressures down to 10psi but it all depends on what you are driving on and what tyres you have, I don't think I'd go that low without bead lockers.
1998 Grand Vitara, 4-door, 2.0L, No Mod's . . . Yet.
Offline sergi
  • 307
Re: Tire Pressure
« Reply #4 on: May 02, 2006, 02:21:19 PM »
I run around 45 psi. Mine are retreads, and high pressures are recommended to avoud overheating the tire (with the risk of losing the new tread). The extra soft rubber makes it not too stiff...
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Tire Pressure
« Reply #5 on: May 02, 2006, 08:05:17 PM »
I'm down around 20-22psi on the 31's on the Tracker.  Think I need to go lower.
The GV has 25psi per tire and I could probably stand to go lower as well.
The Ranger has 30psi and I think I'm happy where they are.  Rangers are kinda porky for "midsize pickups". :P
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: Tire Pressure
« Reply #6 on: May 02, 2006, 08:35:04 PM »
i run 235/60-16 (26psi) on my GV, those tyres are not good on road at all!
but the roads here in Norway is really bad, feels like driwing a BOAT downstreems >:(
can it help to use more pressure?
my winter tyres are 195/75-16, mutch better on road but gooks like goofy's car (too slim tyres)
got new tyres for next season 225/65-16 cooper power king plus, hope they are not too bad on-road.
Offline 2K1USGV
  • 218
Re: Tire Pressure
« Reply #7 on: May 09, 2006, 08:05:13 AM »
If the 235/60/16 aren't good you should maybe go for 235/70/16's. Since theese will have a taller sidewall they will ride smoother on and off the road, but I would still use only 26lbs of pressure in them.
Offline Maroon Monsoon
  • 876
Re: Tire Pressure
« Reply #8 on: May 09, 2006, 10:02:21 AM »
I am running stock size as far as I know that are toyo 800 ultras.. they are stupid tires but are lasting well. I just run the max 45 in them. since for now I primarily only usie it on pavement and a few gravel and dirt roads. They seem to be working fine like that. I think I'll start running at about 40 psi since the center of my tread is wearing a bit faster than the rest
Offline jSager
  • 37
Re: Tire Pressure
« Reply #9 on: May 09, 2006, 10:17:06 AM »
I run 237/70/16 Dayton Timberline A/T at 35 psi.  I've been thinking of upping to 40, as I spend way too much time on road and could use the extra mileage.
jSager
Offline the_maplebar
  • 466
Re: Tire Pressure
« Reply #10 on: May 09, 2006, 10:49:26 AM »
Yes, if you run higher tire pressures you may get a little better gas mileage, but you will likely get uneven wear and the tires will not last as long.
Here is an article on tire pressures, it concentrates on off road pressure but does some analysis of street pressures too.
http://www.4x4now.com/sfjun96.htm
I've seen other people do calculations on what PSI is required to safely carry a load but couldn't remember what that is.  Is it really as simple as
MAX PSI / MAX Load  =  X PSI / Actual Load
It makes sense, but I thought I remembered more calculations being done than that.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: Tire Pressure
« Reply #11 on: May 09, 2006, 05:33:30 PM »
i spoke to a fellow 99 GV 2,0TD driver today, the same car as mine. he uses 235/70-16.
he's car didn't like the bigger tyres,
with 235/60-16 he drove it on 0,6-0,7Litres on 10KM's.
with 235/70-16 it needs 0,8-0,9Litres on 10KM's.
i'm not sure i like the bad diesel mile age >:(
any input????
Offline sergi
  • 307
Re: Tire Pressure
« Reply #12 on: May 11, 2006, 08:26:02 AM »
beerman, your friends car must be the 8v 5 door. Mine is the 16v 3 door. I use 235/70-16 reteads. Mileage has soared really high. Without taking into account the wrong odometer, I think it's above 10l/100km now. I haven't checked,I am too scared! :-[
Besides, your friends car should have 4.3 diff ratio, mine is 3.9! :-X
Barcelona, Europe
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: Tire Pressure
« Reply #13 on: May 11, 2006, 02:39:09 PM »
we both hawe 99's, 87hp Mazda 8v engines.
i've chiptuned mine +K&N air filter, it actually helped on diesel mileage.
guess i got 110+ hp now, i learned that chiptuning lets me drive hard vith good diesel mileage :D
Offline sergi
  • 307
Re: Tire Pressure
« Reply #14 on: May 11, 2006, 03:18:08 PM »
Right, I've got the Peugeot engine, I was actually referring to the 8v Peugeot engine in my other post but later thouht about the Mazda engines...
Mine comes stock with announced 110hp, but it comes out at a measuered 116hp. I supponse mine is a couple of hp higher with the Green air filter. A friend has chiptuned his to 140 hp, now that is nice! ;D
But as I said, my current mileage is terrible. I need a regear soon! :-X What gear ratio do you have?
Barcelona, Europe
