Well....after three months of waiting to get the kit, then another two months of it sitting around the house, I finally took my truck to get the CALMINI lift installed. Didn't think it would be a big deal, neither did the mechanic (who regularly installs lifts and drops on shiny new pickups, hummers, etc.)....until the work started.
Day One - First, they broke off a couple of strut bolts, had to drill them out, and nearly decided not to do the job right there. They were concerned that a lot of bolts were rusty and would continue to give them headaches. Needless to say, I was ready to call them a bunch of a$$holes that only wanted to make "trailer queen tricked out rides with spinning chrome rims," but I stopped myself. Turns out that a couple years up north did put a little rust on my truck, though nothing serious in my opinion. Trust me, I've seen some road salt rust in my day....I'm from Maine, originally. Anyway, I assured them that somebody would have to do this, and I understand if it's going to take longer to do it. Just treat me fair is all I ask. So....they bombarded it with penetrating spray, let it sit overnight, and started again the next day.
Day Two - No problem dropping the diff. Some more bolts broke off in the suspension, though, and they tell me that a couple of the CALMINI bolts (for the strut brace, maybe?) were too long, so they needed to make some up. Then comes the real problem. After hours of working on it, they tell me they just can't figure out how those springs are going to work in the front. "They're stiffer than Super Duty springs. I've never seen anything like it," the mechanic tells me. He goes on to say that he's broken 2 spring compressors already and had four guys in the truck to try to compress the front with their extra body weight. Next, the threads in the CALMINI strut end up stripping from the pressure. Great! Why is this happening?
Well, I show up on the scene, and it finally becomes obvious what's going on. They didn't take out the 1 1/8" coil spacers from my Rocky Road kit! You would think that they would have figured that out, since I told them I already had a lift kit on it, but I guess they thought it was a factory spacer. So, to make a long story short, the front end is now done (10 hours labor!), with one CALMINI strut and one of my Old Man Emu struts that was already on it. I need to take it back Friday to have the rear done (which shouldn't take long). Then, as per CALMINI's recommendation, I'll just get any OEM-type strut sometime in the future to replace the one that got stripped.
Wow...what a pain in the ass. To make matters worse, now the Tracker front skid won't quite clear the lowered diff without a little modification. Arghhhhhhhh. Additionally, one of the bolts attaching the front sway bar to the frame broke off from rust, so that needs to be tapped out and replaced, too. Right now I'm driving around with no sway bar, and only the front done. I need to try to get a front end alignment tomorrow from my trusty "old school" alignment guy, then get the rear portion of the kit installed Friday. I'm planning on leaving for a major road trip Saturday. I hope the hell everything goes well from here on out. The only thing keeping me sane right now is looking at the front end, with those powder coated blue parts...they sure are purty!
I'll keep you all posted. Hopefully my wallet won't get too much lighter on Friday.
