My $500 dollar investment, where do i begin?
  • 1 Replies
  • 1044 Views
Offline Zotol
« on: August 22, 2009, 04:58:01 PM »
Well i picked up a 99 Chevy tracker for $500 recently. Why so cheap? she was put on her side and has some battle scars, ive fixed a few some others need fixing. Anyways it only has 112,000 miles on it and i drove it home 100 or so miles without a hitch. It does shake and feel like something is slipping when in 4wd going up hill on ice but other than that there really isn't many apparent problems. What i WANT to do is get this thing in shape to replace my Cherokee as a daily driver and mild wheeler i want it to do what my Cherokee can, meaning ill need a lift. It has a little rocker rot and there is where i want to start, is the body work. Can i replace it with 2x4 like people do with Cherokees? or is something gonna be cut that's vital. Also fender trimming any pics tutorials? I plan on hercing the inside. And i have some dents here and there with surface rust, and i need to bend the roof lip up on the passenger side front door since the lip was pushed down so is sits under the door seal and leaks, i think a hammer should work fine though. no serious roof crush anywhere. The people who put it on a flatbed beat her up a little. Should i use some filler? is there a cheap paint that matches the stock silver? rockers are my first on to do list
Offline Novadon
  • 205
  • South Carolina. USA
Re: My $500 dollar investment, where do i begin?
« Reply #1 on: August 23, 2009, 10:34:29 AM »
where do i begin?
Suggest finding a wrecking yard TWIN that is mechanically toast or other area collision impacted to acquire the needed tin and trim parts. Finding one of the same body COLOR would be sweet.  ;) The Zuki Grand Vitara version of your Tracker will widen your search.
Here's a good link to junk yard finds which you can tweak by ZIP code for your area..
http://car-part.com/
« Last Edit: August 23, 2009, 10:38:45 AM by Novadon »
03' Honda Odyssey
