removing plastic console
  • 4880 Views
Offline thrash
  • 54
  • thrash thrash thrash
« on: February 24, 2010, 01:32:47 PM »
does anyone know how to remove the plasic around the middle console (around the shifters)????
jeeps are like tampons
every pussy needs one
http://www.cardomain.com/ride/2295298
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: removing plastic console
« Reply #1 on: February 24, 2010, 03:01:05 PM »
The '96 Tracker Factory Service Manual at Ack's FAQ (see link in signature, below) has instructions for disassembling the console.
Do a search for fsm.
You didn't specify which year TracKick (I assume it's a TracKick from your avatar) you have, but if it's 89-98, the above source of info should be pretty close to correct.  Or at least helpful... ;D
Ack
Offline thrash
  • 54
« Reply #2 on: February 24, 2010, 04:05:23 PM »
2001 GV
« Reply #3 on: February 24, 2010, 06:08:46 PM »
You have to remove the rear section (the one that goes over the handbrake) first - slide the seats all the way forward and you'll see two screws, one on each side, if I remember correctly, it helps if you put the t/case into 4LO.
After that comes off, slide the seats all the way back, there are two more screws, one on each side and two plastic "rivets" that are a real PITA to reach - get an allen key or bend a coat hanger into an L and push the center in and then ease the rivet out with a small flat screwdriver - carefully work the t/case boot through the hole, if it's a 5-speed, carefully lift the shifter boot off of the lip on the console (if it's an A/T you'll have to figure that out yourself) and lift the console clear.
« Last Edit: February 24, 2010, 06:11:05 PM by fordem »
