popping noise in front end
  • 15 Replies
  • 3856 Views
Offline CampinMan
  • 10
« on: July 09, 2008, 09:19:27 AM »
I have a 2005 grand vitara that when you are parked with the wheels turned and go to straiten the steering out it makes a popping noise. Anyone have any ideas what would cause this  ???
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: popping noise in front end
« Reply #1 on: July 09, 2008, 09:47:34 AM »
You're still under warranty, aren't you?
XL-7 front coils
1.5" rear coil spacers
Offline CampinMan
  • 10
« Reply #2 on: July 09, 2008, 11:24:50 AM »
I really don't know if it's under warranty or not because I bought the zuki as a rebuilder.
Offline Gemini
« Reply #3 on: July 09, 2008, 09:03:28 PM »
No idea... sounds like something that should move isn't... get the bushings, etc.. all looked at for sure. Have you hit anything that might have bent a moving part?
My 2004 Suzuki Grand Vitara JX build-up thread: here:
My 2003 Mitsubishi Lancer OZ-Rally Edition build-up thread: here:
Offline CampinMan
  • 10
« Reply #4 on: July 10, 2008, 06:43:24 AM »
I haven't hit anything my self but it very well could of happened when it was in it's originaly wrecked through a barbed wire fence. maybe it could of bent one of the steering arms?
Offline IanL
  • 466
« Reply #5 on: July 11, 2008, 12:55:08 AM »
Is it perhaps the tire tread scrubbing on the ground?
Offline CampinMan
  • 10
« Reply #6 on: July 11, 2008, 06:52:53 AM »
No it's not scrubbing the ground. It make the noise most of the time when you go to back out of the driveway and straighten the wheels before backing out. It make one or two pops and then is fine when driving.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #7 on: July 11, 2008, 07:04:37 AM »
You may need to get someone underneath there as it occurs.
XL-7 front coils
Offline gravity_powered
  • 43
« Reply #8 on: July 11, 2008, 07:14:32 PM »
When I had my lift kit fitted the shop left some of the nuts and bolts on the strut tops and the wishbones loose, which resulted in popping and clunking noises. Going over all the nuts and bolts could reveal the problem.
A dry and/or worn ball joint could also be causing the noise.
« Last Edit: July 13, 2008, 06:14:06 AM by gravity_powered »
'98 2.5 V6 Grand Vitara
TJM Bullbar
Lightforce 170 driving lights
Wombat Racks roof rack
235/70/16 Toyo Open Country A/T
Offline Gemini
« Reply #9 on: July 12, 2008, 04:19:53 PM »
I may be grasping at straws here... but this only comes to mind since I have recently installed larger tires on my GV. Are you by any chance running tires that are too big for the wheel wells, and so they're rubbing? Figured I'd throw that in there.. just in case it was possible. haha.
Hope you get things figured out. You'll definitely need to get someone up front to watch/listen while this happens I would say.
-Glenn
« Reply #10 on: July 14, 2008, 08:05:54 AM »
Sounds like a worn out rod end on the rack & pinion steering.  I've replaced a few already on my 2000 GV.
Offline CampinMan
  • 10
« Reply #11 on: July 17, 2008, 02:08:37 PM »
I took it to the local suzuki dealership today. They thought that both front wheel bearings needed to be replaced. Does that sound possible with only 34,000 miles on it. Also how hard are the bearings to replace. The shop wanted $873 to replace them
Offline Armour
  • 360
« Reply #12 on: July 17, 2008, 03:45:52 PM »
The bearings aren't that hard to replace. Are they a hub assm on that truck?
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline CampinMan
  • 10
« Reply #13 on: July 18, 2008, 07:12:22 AM »
Yes it is a hub assembly. They are kind of expensive though.
Offline clockwork
  • 19
« Reply #14 on: July 19, 2008, 10:20:30 AM »
ive had that popping noise when i first bought my tracker too.
my problem was a worn bolt/bushing on the swaybar i believe.
all i had to do was take off the tire and replace it, finished in about half hour.
hope everythings goes well and you dont spend too much on it  :D
~2000 Tracker~2.0L-16V~5spd manual~4-door~4WD~K&N air filter~Kenwood Excelon KDC-X491 CD Receiver~polk audio db650 speakers~US acoustics USX4095 amplifier~work in progress
