Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
wheels
wheels
gsherred
112
2
wheels
August 21, 2011, 02:41:26 PM »
Does anyone know what aftermarket wheels will fit a tracker with no caliper interference? I've been looking at a set of cragar soft 8s or d windows with 4" of back spacing in a 15x7 size.
1985rz500
36
Re: wheels
August 21, 2011, 06:41:26 PM »
I had a set of 15X7 AR wagon wheels on our`97 4dr. Fit and worked perfectly. Just went in to the wheel shop and told the guy what vehicle they were for and he ordered them for me. Take a look at Tire Rack
Still standin'
chevytracker
126
Re: wheels
September 16, 2011, 09:03:05 PM »
It's around 3-1/2 inches isn't it???
I likeyour choice in wheels, someone has a set in the classifieds or check the below link.
http://www.lowrangeoffroad.com/index.php/suzuki/sidekick-tracker-x90/wheels/pro-comp-rock-crawlers/series-98/rock-crawler-series-98-gloss-black-monster-mod-wheel-pcw98-5885.html
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more. 95 Tracker with all Calmini bolt ons. 96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
nprecon
2318
52
ONWARD... through the fog!
Re: wheels
Reply #3 on:
September 17, 2011, 08:21:24 AM »
Tuxblacray has a set of 5 soft 8s for sale in the classified section for $200. They are 8X15. Good price. Virtually any tire you put on a second gen truck will have rear fender clearance problems if you go larger than a 30X9.5 or 235/75 series on a stock rim. So whether it is 7" or 8" I don't see too much difference. The issue is either the tread width or the series cross section.
http://www.zukiworld.com/forum/classified-ads/5-cragar-soft-8-black-rims-
$200/
I've thought long and hard about just going with used 6X16" Vitara steel wheels and running 215/85/16 tires on them. 30"+ height, 6+" tread width and the
full
use of the existing stock wheel well. Sand the rims down, wipe them with Xylol, then spray them Rustoleum semigloss black... and you have some inexpensive "Soft 8s" that you
know
will fit for a heck of a lot cheaper than buying new rims. You still have to correct the axle gearing to pull 30+" tires though. Like:
http://www.tirerack.com/tires/tires.jsp?code=yes&KEYWORD=tires.jsp_Firestone_Destination_M%2FT_Tire&partnum=185R6DESTMT&GCID=C13674x012-tire&tireModel=Destination+M%2FT&tireMake=Firestone&
or
http://www.treadepot.com/tire/B61161.html?CID=21
or
http://www.nextag.com/Hankook-DYNAPRO-MT-RT03-676450522/prices-html
or
http://www.nextag.com/Goodyear-WRANGLER-DURATRAC-1240303312/prices-html
Or
if you want even more aggressive the original Interco TSL:
http://www.intercotire.com/tires.php?id=18&g=1
Last Edit: September 17, 2011, 08:40:45 AM by nprecon
'02 Chezuki Tracker with a 2 Liter and 5spd. It works for me!!!
