Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
Boondox coil spacers for GV's
the_maplebar
466
July 19, 2006, 08:22:28 AM »
I have noticed that Boondox has different coil spacers specifically for the GV's and was wondering how they fit? I know some of you have purchased and installed them already, so let's hear about them.
http://www.boondoxmotorsports.com/zuk_suspension.html
I can tell you that Josh's (JDMCRX) coil spacer's fit great. They were easy to get on, but tight enough that they stayed in place on their own while I was positioning the rubber isolater and spring.
I would also be interested to know if anyone has experience using Sidekick coil spacers. Do they fit fine, is there even a need for coil spacers made specifically for the GV or are they the same thing?
http://www.zukiworld.com/forum/index.php?topic=35.msg111575#msg111575
[/url]
lowrezolution
292
"Get bent!"
Re: Boondox coil spacers for GV's
July 21, 2006, 05:11:12 PM »
Mine fit excellent, the only issue was the front would have sat higher if I hadn't added an extra spacer between the boondox one and the spring mount.
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Autobot
189
Danger Can Happen!
July 28, 2006, 07:31:29 AM »
What size spacer did you fit to level out the back, and where did you get it from? If you didn't would there be a noticable difference between the front and back? I was looking at the BD spacers as well. For $100 it seems like a good price.
Got Tracker?
2000 2dr. convertible, stock.
bzzr2
1011
3
Reply #3 on:
July 28, 2006, 10:22:06 AM »
i have a 1 inch spacer in front and a 1.5 inch spacer in the rear of my tracker and it sits well. if you did order the boondox spacers you could either trim 2 of them down for the front a bit and maybe add an extra spring isolator or 2 to help keep the rear up.
09 taco reg cab short box 4x4
