thanks, I don't have any idea how many hours went into it, but it wasn't too bad. It's all one piece of sheet metal that me and a guy who is a metal fabricator for a living mapped out, he did one half, then I did the other after I knew what to do. all the measurements were based off a cardboard template that I made. once I plasma cut the piece, the top 90 degree bend and bottom 45 degree bends were done on some big bender type deal (didn't see that part since my friend sent it there in the middle of the week after I plasma cut it). once that was done, I did some more measurements based off the template and cut out some notches to fold it into shape. I just used an oxy-acetalyne torch to heat and bend it, again, my friend did one of the bends, then I knew what to do and did the rest. There are only 4 seams on the top that I welded together, most of the welding is on the brackets.
I can't wait to finish reinforcing it so I can get crackin on some tube work for it. It will aso be a ton stronger once I do that, and then I can really take advantage of having the bumper without worrying too much about hurting it.
