Ok, still having problems with this.
Originally, I just got a CV from a Sidekick at a wrecker and pulled the bearing retainer off it and put my original CV shaft together and ran with it. Seemed to be working fine until I tried out 4wd, turning right in a flat parking lot. I took it apart and what happened was the whole inboard (diff end) joint had completely popped out of the green cup in my picture. This is probably what happened the first time too.
So I bought a brand new CV axle and installed it today. Took it out of my shop in 2wd with the hubs unlocked, no problem. Drove across the road to the gravel patch, put the t-case in 4L and locked the hubs, drove straight for about 5 feet, turned left for about 5 feet, and turned right for about 5 feet and then all hell broke loose! I took a look underneath and sure enough, the CV joint had separated again. It was binding so badly that it somehow compressed my whole left-front suspension to the point that I could only see a few inches on my strut piston instead of the usual 5 or 6".
Removing it was a pain in the arse as well. The first broken shaft I removed, I just used an angle grinder cause I knew it was totally broken anyways. This one I thought maybe I could repair so I had to use a 2 foot long prybar between the shaft that goes into the diff and the CV.
So pretty much it looks like my CV is too short. I never had any problems with CV's with my old aluminum 1997 Sidekick diff, but it seems like as soon as I put in the steel diff with the shift-on-the-fly removed and 5.13 gears installed, something ain't quite right and it doesn't want to work.
I know there is a 1" offset to the Grand Vitara diff because of the SOTF, but is that 1" in the carrier or in the 3rd? I'm thinking it's in the 3rd because I phoned Hawk and they said the Grand Vitara pound-in 3-bolt shaft is about 1 or 1.5" longer than the same part on a Sidekick, but they told me I needed to run the Sidekick pound-in shaft in the Grand Vitara steel diff. Is it possible that they got mixed up and I'm actually supposed to be running a Grand Vitara pound-in shaft?
Advice/insight urgently needed as I have a 1200km road trip to northern BC coming up on Saturday!
