Rear winch on GV
  • 2106 Views
Rear winch on GV
« on: July 21, 2011, 10:55:22 AM »
I don't know how long or well this will hold up as long as it stays dry but I took a $200 quad winch and mounted it to a class III hitch for something different. I still need to paint or powder coat the shackle mounts and where they welded spacers to the top to lower hitch half an inch.  I think the spare tire will rip from door before winch breaks free.
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
Re: Rear winch on GV
« Reply #1 on: July 22, 2011, 10:02:02 AM »
What's the rating on that lil guy?
You can use a snatch block and do a double line pull to increase pulling power for sticky situations..
Offline IanL
  • 466
« Reply #2 on: July 23, 2011, 12:28:11 AM »
In Europe, we have towing hitches with a ball on the tug, and I have a winch which attaches to a plate with a hole and an elongated slot, which just goes over the ball.  With no strain on the winch, it hangs down, and when the strain comes on, it rises up in line with the towline.  When not in use, it lives in the trunk.   If you have a fridge socket in the trunk, you plug in there for power. Quite neat, and no installation work required.
« Last Edit: July 26, 2011, 12:46:32 AM by IanL »
« Reply #3 on: July 23, 2011, 06:21:54 AM »
What sort of amp rating are you using - a Warn 6000# winch pulls over 400A at full load - fridge maybe 10A.
Offline 3stagevtec
  • 204
« Reply #4 on: July 25, 2011, 03:30:12 PM »
^ I wondering the same thing!
Offline IanL
  • 466
« Reply #5 on: July 26, 2011, 12:43:56 AM »
Maybe I was being fanciful about the fridge socket - I actually ran cabling from the battery to a socket in the trunk of my X-90.  The documentation doesn't state the current loading, but I included a 30A fuse, and it hasn't blown.
The winch is rated at 2000 lb static pull, so it's no heavy weight performer, but it is very geared down, so quite effective.
