Manual transmission difference 2.0&1.6
  • 2436 Views
Offline Derikr
« on: January 09, 2019, 07:39:46 AM »
I have a 2003 2.0 chevy tracker 2 door 4wd manual and the transmission is bad and was wondering what the difference is between the 2.0 and 1.6 manual transmission. I know its probably already been asked but thanks for the info
  • 4312
  • 167
Re: Manual transmission difference 2.0&1.6
« Reply #1 on: January 09, 2019, 08:23:05 AM »
When you say "1.6" what vehicle are you referring to - the SQ416 or second gen 1.6 (same body style as your 2.0 - SQ420) or the SE416, which is the previous generation of Geo Trackers?
As far as I'm aware the SQ416 & SQ420 share a transmission, but it is not the same transmission that was used on the SE416s - having said that the two engines share a bell housing bolt pattern and the transmissions can be adapted to work.
One point to consider, SQ416s were I believe quite rare, SE416s were plentiful, but, they are all likely to have substantial mileage on them - have you considered rebuilding your transmission - does the problem require more than just a bearing and synchro replacement?  Just my way of thought when it comes to used car parts - , better the devil you know ...
Offline Derikr
« Reply #2 on: January 09, 2019, 10:31:25 AM »
I'm sorry I should've been more specific. The 1.6 out of the geo tracker and the 2.0 chevy tracker. I was wondering if they had the same manual transmission
Offline Derikr
« Reply #3 on: January 09, 2019, 03:49:46 PM »
My transmission is shot and is binding up and can't find another one and was wondering what other manual transmission would bolt up
Offline Derikr
« Reply #4 on: January 29, 2019, 07:41:06 PM »
Can anyone let me know what difference are between 90s moder geo tracker 1.6 manual transmission and the chevy tracker 2.0 manual transmission. I've asked and got some difference but my transmission bearings went bad and broke a couple of gears that are discontinued. I have a chevy tracker and having problems finding gears for it. Any help would be much appreciated  thanks
