Fuel Injectors Won't Fire, 00 2.0L
  • 2083 Views
Offline zbeamanx2
  • 9
    • My Instagram
« on: September 18, 2018, 01:21:13 PM »
Howdy everyone, I hope you're having a fine day.
I've got a 2000 Tracker with a rebuilt 2.0L and now that the spark plugs are finally firing, the fuel injectors won't. I checked the coupler that hooks up to the fuel injector harness and it's receiving a weak signal. Any ideas?
Got a 2000 Chevy Tracker that's got a 2.0 L4 and no idea how to convert it to 4wd.
  • 4319
  • 167
Re: Fuel Injectors Won't Fire, 00 2.0L
« Reply #1 on: September 18, 2018, 01:41:33 PM »
Define "weak signal" - if I remember correctly one side of the injectors are connected to +12V and the other is pulled to ground by the ECU - do you have a good +12V feed?
Offline zbeamanx2
  • 9
    • My Instagram
« Reply #2 on: September 18, 2018, 03:50:22 PM »
No, it's significantly lower
  • 4319
  • 167
« Reply #3 on: September 18, 2018, 09:03:42 PM »
Well - you know where to start looking...
The injectors are powered directly off of the fuel injection system main relay which get's it's power directly off of the fuel injection fuse - sounds like you have a bad connection somewhere.
