Leaking front Diff fluid
  • 8 Replies
  • 2546 Views
Offline Zwiser
  • 11
« on: October 03, 2012, 02:19:09 PM »
Hello, I noticed that there is differential fluid leaking out of the right front axle where it comes out of the housing. I noticed this after cleaning out all the packed mud underneath.
Its defiantly Diff fluid and It comes out faster after your done driving it.
What do you guys think the problem could be?
Offline jcowdin
  • 111
Re: Leaking front Diff fluid
« Reply #1 on: October 03, 2012, 02:56:34 PM »
If the fluid is coming out of where the axle goes into the housing of the differential, your axle shaft seal is leaking.  If there was a lot of mud around it, some dirt probably got worked into the seal and ruined it.  Mud is tuff on seals and brake linings.
The Price is Right!
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #2 on: October 03, 2012, 03:17:22 PM »
jcowdin is on it.  Sounds like the seal on the passenger side diff housing has worn and is allowing gear oil to pass by it, if I am understanding your description correctly.
The housing seals on the passenger side of these trucks do wear down over time and leak.  With the stock fixed hub locks, the front axles continually turn, even if you don't have 4WD engaged.  There is no carrier bearing on the passenger side, only the oil seal.  The CV stub simply pops into the side of the diff into the side gear of the differential... which allows some up and down movement of the CV shaft shoulder when driving - which when combined with the constantly turning CV axles, causes more wear on the lower seal surface until it erodes away.  Suzuki now sells a bushing that is supposed to reduce this wear.  I have never tried one.  maybe someone else has and will pipe in.  Installing manual hubs reduces the wear on this seal too, because when they are unlocked, your wheel turns but the CVs don't.
The replacement seals aren't that expensive nor difficult to remove.  In fact, you can remove the old seal and knock a new seal back in with a large socket or seal installer in probably less than 5 minutes.
However, the devil is in the details.  Drain the gear oil.  To access the seal area you either; jack the front of the truck up, support the truck with jack stands safely on the cross member or frame rails, then remove the passenger front wheel, disconnect the caliper and hang it by wire out of the way, disconnect the sway bar, tie rod and remove the strut bolts to allow the control arm to be able to drop (with a jack under it to control its movement slowly) then pull the snap ring and washer off the outside of the CV axle which will allow it slide out of the hub, then remove the CV stub from the housing by carefully prying/tapping/rotating the CV so it pops out so you can access the housing to get at the seal.  Don't tug on the outside end of your CV.  Sometimes they can put up a fight and you have to go at the tapping with a BFH. There is a small "c" clip on the stub end of the CV shaft inside the diff which can hang up on the lip, hence rotating it when your are prying sometimes helps it release easier.  Make sure the little C-clip is still on your stub end when it comes out.  You don't want it floating around inside your diff.  It is hardened steel. If it isn't there, chances are it popped off inside your diff and you will need to split the diff and go after it.
Alternately, you could remove the 4 bolts to the front drive shaft, tie the drive shaft up SECURELY, remove the 2 bolts securing the nose of the diff to the cross member, then remove the 4 and 3 mounting bolts from the housing on each end OR remove the 2 bolts holding the housing brackets and attempt to wrestle it out that way.  My experience is you also have to remove the front bolt from the front passenger side control arm and ratchet it downward about an inch to allow clearance for the CV to drop enough to pull/come out.  It also helps to remove the four bolts holding the rack and pinion and push the R&P upward for needed clearance.  This process works (IMHO) better if your truck is on a lift versus jack stands.
Personally, I would NOT attempt the alternate method by myself.  Two sets of hands are "more better" and you will probably still fight the CV to get the housing to pull away from the CV.  The front housing isn't super heavy but it sure is awkward.  Especially when you are trying to extract the CV stub at the same time.
Assembly is reverse of the above.  Make sure to coat the end of your CV stub with a coat of grease so it slides easily into and by your new seal.
« Last Edit: October 03, 2012, 03:31:25 PM by nprecon »
Offline Zwiser
  • 11
« Reply #3 on: October 03, 2012, 04:29:03 PM »
Alright thanks, Any online suppliers that keep the new bushing in stock?
Offline nprecon
  • 2318
  • 52
« Reply #4 on: October 03, 2012, 05:19:14 PM »
There are many.  Rockauto.com is one of my favorites, but you could also call Brent at Trail Tough and other venders that support this site very well and they could and would hook you up too.
Offline bush buster
  • 263
« Reply #5 on: October 09, 2012, 06:31:11 AM »
I bought the bushing from Suzuki. I think it was about $80CAN but still cheaper than Altered Ego.  You can try just a new seal but it will probably leak again before long.  You could check the axle for play inside the diff housing first, but again you may as well install the bushing at the same time because it is a preventative measure as well. If you want manual hubs, the Altered Ego combo package containing rebuilt hubs and the bushing could be worth it.
Offline talonxracer
  • 1284
« Reply #6 on: October 09, 2012, 07:03:02 AM »
Yes there is a Suzuki TSB regarding this, it specifes replacement of the seal and install of the nylon bearing support. ouch! 80$ from suzuki. I just dropped off the specs to have my CNC guy make a few from Delrin, substantially cheaper than Suzuki.
Offline nprecon
  • 2318
  • 52
« Reply #7 on: October 09, 2012, 08:07:37 PM »
Delrin is some tough stuff.  What's that Suzuki bushing made of?
Offline talonxracer
  • 1284
« Reply #8 on: October 10, 2012, 06:09:55 AM »
Suzuki's bearing inserts are plain old nylon66, also a fairly tough plastic, but will eventually fail due to hydrocarbon degradation(diff oil).
